I had the same problem with the Imperial. Grab the original wiper and go play match up at the stores. In my case, the solution was some sort of RV wiper blade at Car Quest.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
