Sadly, the crank and rods are already balanced and installed, but the engine is still out.
You say the crank and rods are balanced and installed, I assume you have pistons already on those rods? If thats the case, changing your pistons will likely throw the balance out, and youll need to do it again.
I used to care but....... things have changed
