Originally Posted By Gearbox
I thought it was just me, it did look ugly. The top plate looked like the carbs would be sitting on a angle, not sideways or straight. I see all the sheetmetal intakes but wonder if a cast Indy or M1 tunnel ram could have the ports opened up to be used on B1 heads? I agree the single B1 intake is probably the way to go, just looking for the cast tunnel ram nostalgia look. May just be easier to build a Indy setup and pass on the b1's.
Just angled lines up a throttle bore with a port
wave
