Originally Posted By wesw
this is the link for the 16 volt alternator. $146.48 [NEW]
http://www.bonanza.com/listings/16-Volt-...-Type/226735161
if you are running a 12 volt system they have it too. the mount is from mancini racing. P/N BMAB050CT for $125.95
if you run a MSD crank trigger that part is MRECT-30 $43.95
I would be leary on the Rareelectric alternator. I had a 12v and it lasted less than a year and barely charged the battery. I run this one and like it quite a bit.
http://www.jegs.com/i/JEGS+Performance+Products/555/10171/10002/-1
5.53 @ 125 1/8th on the launch control..more left in her!
