Well pulled valve cover and found pushrod came out from rocker arm. Reinstalled push rod and cranked engine over with coil grounded. There was little to no lift on push rod so figured wiped cam lobe off. Removed intake and found #7 intake lifter shot. Piece broke from inside guts of lifter and it was laying in valley. The cup that holds push rod. Circlip was still in lifter body.
Dodged a bullet I guess.
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
