Very true. You can always cut down. A bunch of rear force can tilt the front up, but if you have a good front spoiler like a splitter, probably not issue.
Our circle track cars only run half that height. It does make a difference. Just wonder if you are limited HP, the extra drag might hurt you? Real way to find out is good testing.
