Nice pictures, would you happen to know the backspacing? Also how far does your tires stick out front and rear? Personally I like when they're almost flush with the body.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far.
Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be.
Don't protect a feminist when the collapse comes!
