The other thing is the hard starting is only when cold - if the engine is warm it will light right off.
that rotor is $8 & change out the door (or make your own), NAPA prices ain't never cheap & you might need some choke (just the right amt) even in good weather. I'm not thinking making a trip for that rotor will fix it but I want every subsystem dead on (to stay ahead of the chebby boys )
