An inexpensive AP store mechanical gauge is a low cost diagnostic. 170k is a fair amount of miles also... bearing clearances may be on the high side. Heavier oil may help if pressure is dropping below 10 or 15 psi at hot idle. 15W40 diesel oil or 20W50 car oil may keep it going.
