Should I mark or score anything to help with the cars alignment whenever I get ready to reassemble?
Pop the upper ball joints apart and leave the upper control arms attached to the car. Everything else "should" remain the same as far as alignment.
Another option is to unbolt the lower ball joint/steering arm from the spindle rather than popping the upper joint.
