It will probably continue to leak the rear main on small block are pain to keep from leaking Use good silicone sealer on cap and do not apply in cold or damp conditions. Use grease on seal itself I prefer to use Mopar gasket in a can for the pan gasket. Assemble and do not run for several hours this lets silicone set up . By the synthetic oil seems to love to leak on the 360s seeps right past gaskets if this is the problem use high mileage oil it really does help reduce leaks
