Re: Has the QC on 440 Source cranks improved?
[Re: rowin4]
#1788964
03/28/15 08:01 PM
03/28/15 08:01 PM
Posts: 15,439 Val-haul-ass... eventually
BradH
Taking time off to work on my car
The tales of bad cranks seem to have been rumors perpetrated by people who had no actual first hand knowledge but are just down on products made in China.
Bull$hit. More than one person who builds / built engines for a living has provided details in the past on certain cranks whose finish tolerances were far from ideal (excessive journal taper, inconsistent sizing from one journal to the next).
I know some of the brands seem to have gotten better. My 2nd Eagle crank is surprisingly good (my first one needed the mains cut .010"). The only thing I don't like was that the crank snout where the damper fits was on the small side, so I needed to buy a new SFI damper to make sure the press fit was acceptable. My original SFI damper had already been honed to fit an OEM-sized snout and would have been too loose.
Just because some people don't want to hear that their budget parts might not have been machined as precisely as more expensive & higher quality items doesn't make it a "rumor".
Here we go, The question was about 440 Source and now your saying how your Eagle crank was a piece of crap. Just to let you know I had my Eagle crank checked by a top Engine builder and it was good to go. If my 440 Source crank needed to be turned .010 it would have been sent back.
1. Original poster asked about 440 Source cranks. 2. Stanton replied in regards to Chinese parts categorically, to which I (obviously) disagreed with his comment. 3. I also pointed out the my first Eagle crank (also CHINESE), needed the mains cut down, but the only complaint I have w/ the 2nd Eagle crank (still CHINESE) is that the snout is sized on the small side and I bought a new balancer because I couldn't re-use my original balancer since it had been honed to fit an OEM crank and would be too loose on the smaller-sized Eagle snout.
Nowhere did I call my Eagle crank(s) a "piece of crap", YOU did. If I didn't think it was a reasonable piece to use, I wouldn't have bought a 2nd one. However, I surely knew to expect that it might need some correction work, just as previous posts on the 440 Source cranks also told people to expect.
I didn't pay Callies prices (I got mine for $600 each), and I didn't expect Callies quality, but plenty of people on here seem to think you can honestly get the quality w/o the price from so many budget offshore parts. There's been enough evidence of that being unrealistic over the years that you'd think nobody would even debate the topic.
For the OP, my is to buy the Molnar, even if it costs a bit more than the 440 Source when the cost w/ shipping is factored in.
