After much hassle i was able to get the amp loose but i can not get it to unplug from the wiring harness at the back of the unit. Does anyone know if the amp has permanent wiring or should it unplug at the back of the unit. I tried all i could think of and i cant get the two wiring harness free from the rear where they plug in. Thanks for any advice. Stu
