Quote: this is absolutely the problem the gear is being driven forward to engage the flywheel (as it should) but it is already engaged so it binds. this story would not have ended well for that starter if it had started up!
So if this is my problem how do i fix it? as either the starter gear is to long or the flywheel teeth are to close.
