The small ball joint used in the uppers was phased out for 73. Many don't realize the conversion from 10" drum to disc for a 73-76 A does not require the new upper control arm as a 72 and back does...
There are a very select few 9" small bolt pattern set-ups that I have seen on 6 cylinder cars as late as 75. They're few and far between...
...FAFO...
