did pull starter from car and bench tested as you said,bendix extended and starter spun.still at a loss.Thanks for the response.
Check to see if you have good clean grounds. From your description it sounds like there is not enough amperage passing thru the cables to the starter, which would indicate a poor or dirty connection.
