hardly think that thing will lose prime using the spacer you have. Probably run it around the "add" line. My dad had one of those aluminum Summit pans on the Duster when I got it. Got one of the lucky ones that leaked, even with the reusable gasket. I swapped it out for a 47RH pan I had laying around. I do miss the drain plug, but could add one to the steel pan I suppose.
