I have checked the power valve and it is okay. Where should the level be in the bowls? What should I look for when checking the vaccuum? Where is a good starting point on the mixture screws? Thanks for the info.
check the vacuum..where the power brakes or pvc on the carb is...
u want to compare that with the power valve..u dont want the power valve opening to early cause that dump extra gas into the carb..
float level should be at the lower edge of sight hole in side of bowl..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
