If you need to fine tune the gauge there's a small window on the back of the gauge that will adjust the pointer...Move the "teeth" a little at a time...Only do this if you've confirmed the reading through a secondary gauge or temp reader... I'll usually adjust to center the gauge at normal operating temp if needed just to match up the sender to the gauge
