Here is what I have.
78 Warlock, 727, 8 3/4 3.55, mini tubbed, running 295/40/18 on the street. (Have access to 3.91 and 4.56) currently running block hugger headers and 2 1/2 in exhaust all the way out.
1972 400 block (short block assembled and zero decked)
3.90 stroke crank
H beam rods
CP flat tops
Stealth heads (bowl blended and cleaned up)
Comp 26120 beehive springs with retainers and 10 deg locks
Crane gold 1.6 rockers
Leening toward RPM intake, but not married to it,
Carb? I will start with an 850DP I have hanging on the wall.
Cam? My original thought was MP .557 (not looking for aggressive ramp cam) This will be mostly street driven with occasional track days. Now I have been looking into hyd rollers like COMP XR292.
Not sure if I want to step up to hyd roller or stay with a good old solid flat tappet. Looking for pros and cons for each.
I will have a converter built after I see what it will do on a dyno.
