Anyone have any recommendations on a cam? The motor itself is a bone stock 76 440 from a motorhome. I have an Edelbrock Performer intake and a set of headers. I'm also using the stock T-quad carb which I will get rebuilt. The trans has been rebuilt with a shift kit and a mild stall converter. I told them I wanted a converter that would work with a stock motor and have room for improvements. So what cam would you recommend and can you explain the specs on it?
Thanks!
