Is there any way to get a 71-74 wiper linkage to work on a 70? Are they the same length?
Or I guess it would be 72-74?
Yes you can with the right combination of parts. If you have a 70-71 motor you would need to change the drive pin inside the motor and then use the 3431518 crank and 3431514 link. If you don’t care about the numbers on the motor you could use the motor, crank and link off any 72-74. If you are going with the 70-71 motor and changing the drive crank there is a timing issue inside you would have to deal with. Contact me and I’ll help with that.
