I know the 64 Plymouth.I'd bet the rear ones are close, 25 lbs. The Dodge front is way heavier than the Plymouth which is 23 lbs. All the Plymouth brackets together weigh 26 lbs. Again I'll bet the Dodge front is heavier. The carbon fiber brackets shaved 23.5 lbs from mine. Doug
