The pitting is only on the crank side of the bearing... the condensation makes sense because before i pulled it years ago it was only run for short periods..
The grounding of the block puzzels me I had the usual ground wire and i think a solid mount on one side. I wouldnt think there would be any current flow...could someone expoundon that please..
V10
