Here's the only pic I had taken of my '70 Barracuda's rh/pass side, don't have one at all for the lh/driver's.
Can basically see how the firewall area was loaded with undercoating, and traces under the diagonal brace.
While the control arm area and inspection plate see a mask pattern, there were traces of undercoating oversprayed onto each upper arm.
Way to go on getting the ole 426 hemi running, good for you, Troy, hope you have lottttts of fun times & many miles with it, and may all that good work from the past keep you confident for this future resto on the 'Hemi Cuda.
