Has this combo idled okay before for you and just now started dying at isle? Or is it new to you with no previous experience with it?
A few things to check; vacuum leak, initial timing, fuel delivery, dirty fuel, bad PCV valve, proper idle jet, proper idle air bleed, proper float level.
Master, again and still
