I had this problem when I converted to electronic ignition. In my case, I wired the ballast reistor wrong. Mine was trying to start with the resistor in the cicuit, the starter was drawing enough power to prevent the ignition from getting enough power to ignite. It turned out that I had the bypass for starting on the wrong side of the resister. Just a thought.
