Don't know if I did good or bad but the set of 6 OEM Reman injectors was $1500.00 and the labor for instal was $700.00. Havent put any real miles on it since I just picked it up.
Mechanic said water in the fuel was the most likely down fall plus 400,000 miles on the truck. Not the orignal owner so don't know if they were changed before.
I put 10,000 miles on it in the previous month.
1967 Coronet R/T 1970 Coronet R/T 1997 Dakota 2006 Ram 3500 DRW
