BUT harness can be pulled out from A pillar without need to remove the plug... diff stuff is reinstall it
Smart move is to attach a messenger line to it when removing, to be used for pulling it back in.
Yes that is....
Too bad I'm pulling it out of one car to put in another
Thank you for all the replies guys. I'll check out all of the links provided. I had already found the extractors that are round... but it looks like a great way to stab yourself in the hand with the bit you aren't using
2016 Challenger Scat Pack Shaker 1000 ci Brass Era Speedster project
