Quote: Portable/Small Media blaster - I have a 60gal compressor, seems like an option?
That is what I would use. Soda if possible. Just avoid areas where it could go in the car. Media will get all the nooks and crannies. The rest you will need to manually remove with various media/grit wheels or discs.
