Re: factory air 1969/dart w/340
[Re: kentj340]
#1748835
02/09/15 09:08 PM
02/09/15 09:08 PM
Posts: 119 Minnesota
IEAT4DS
Minnesota
See the 340 engine assembly manual reprint here:
http://www.faxonautoliterature.com/1969-Dodge-Dart-Engine-Assembly-Manual-Reprint-P20360.aspx
Very nice to have - shows Mopar drawings of all the brackets and part numbers for A/C on a 340 plus more. I have the Plymouth version of the manual, which might be the same as Dodge. I think these drawings are a small part of what used to be available at Hamtramck Historical but were "seized" by Chrysler.
This manual has drawings of all the "engine dress", the stuff put on the engine at the assembly plant, such as throttle cable, accelerator pedal, carb, PVC, fuel pump, starter, engine and trans mounts, choke, fan drive, alternator, PS, A/C. The drawings don't show anything done at the engine plant.
PM me if you want a peek.
Thanks Kentj340, I will be ordering that resource.
