Quote: i dont know how my crap is 9* down on the dana .......
at one time that was a good thing.
is that 9* minus driveshaft angle?
- 9(down) on the dana and -3(down) on the back of the tranny.. not -2 as previously posted... so im taking its -12* down
When your posting your numbers where are you measuring with a angle finder? Off of both the tranny and rear end in relationship to the 90 mark or what? If in relationship to 90 degrees are both measurements on the same side or opposite sides of the 90 mark? If both are on the same side then you need to subtract them from each other which would equal six degrees difference between the two angles, if there on opposite sides of the 90 degree mark you add them together which ends up equaling 12 degrees like you posted, which is way to much
see pic above for the measurement on the dana i am gonna triple check it all again today... but im sure they are opposite
