With a 1972 400, What's the difference IF any between the Vacuum advance on a 4spd vs. auto. Also is there any difference with 2bbl vs 4bbl? Thanks
If you have a '72 FSM it will have the specs for both. You will then know if they were supposed to be the same or not.
