If it turns opposite direction could the crank still be used?
I had a reverse rotation/marine 440 ages ago (sent it to Melbourne to sell actually) and the reverse ones have the hashing on the rear main seal area going the other direction to a "normal" crank. So it would tend to push the oil outwards probably if used the 'wrong way' ?
