The most important part is getting the acc pedal in the top right corner. It all falls into place after that is done.
Original 69 Daytona
Yeah...
I just wasn't sure if the replacement carpets have the same amount of overlap(where the finished seam winds up) to the rear carpet section as the originals do.....I realize that, as you stated, once the placement of the gas pedal is set, then all falls where its gonna be...
Thanks everyone..
MB
