"Carb Guru" at you service.....Yes the 800CFM carb you have has a 1 11/16 base plate on it....You will need a 1 3/4 base plate for the 950 body swap you want to do so it lines up correctly.... ..Merry Christmas, Jesse @ BIGS!!
www.bigsperformance.com
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
