I am going to have the one way valve welded into my headers, but want to see pics of how you did it. Also interested in seeing top dollar installations.. unlike my generic kit. Thanks.
I always use a pipe nipple to weld into the collector,
cut the one end at a 45* angle and install it
in the middle of the collector making sure that
the flat of the 45* is parallel with the collector exit.
If you want to fancy it up for a touch better flow
grind the forward side of the nipple thinner for
better flow. I'll see if I have any pics
