Ok so I called MSD I turned the waste spark off as the instructions suggest for the 88864 harness and MSD is saying it should be on anyone with this harness care to share the setup you have when I had it running earlier last week all the settings were factory settings I changed the map curve to 0 not using a map and the timing curve.
