easy to just turn the axle and count the yoke turns.Its not exact but real close.Example 3.91 the axle will turn almost 1 turn to 4 turns of the yoke.Its easy to pull the cover on a dana and count the teeth or look at the ring gear for ratio.Rocky
Chrysler Firepower
