I didn't replace anything.I bought the cam from a guy that was parting our a 622. Best is building him a new 622 and would not use any used valve train parts. His Indy block had a previous repair that did not work out and he started over fresh.You still have not said what cam bearings you have in your block. If they are 55 mm then this cam makes no diff.
