I used the Schumacher mounts without first knowing it would change the shaker height making it too high.
A buddy let me try out his shaker to see how it would look using them.
Looks like I'll have to pull out the engine and sendin the K member.
Not an optimal solution, but you might use 3/8 spacer between k-frame and rails. Some here said racers have used this method for years.
