I installed the trans first with convertor, then dropped the motor in. i marked the convertor and flex plate, so i know what the pattern is. i believe the weight on the front of the convertor is "pinched" as i cant get the convertor to spin at all. i will loosen the trans to engine bolts and re-align and see if this solves it. i have a feeling it will. sorry for the confusion and thanks for your help
