Quote: Correct, original AFX cars used the bolt on 64/65 Race Hemi scoops (64 was aluminum, 65 was thin steel, same exact shape and size). Altered (higher) opening hight fiberglass versions came later from the aftermarket.
Interesting. I thought all Altered wheel base cars used fiberglass hoods along with doors fenders, dash and decklids. So both of these cars came thru with steel hoods? what about the add that shows fiberglass parts?
