I bought Pertronix II #91381A, with matching Flamethrower II coil #45011. I deleted the ballast resistor, spliced the wires together (IGN 1) and ran them to the + coil, and ran the brown IGN 2 to the + coil. Then I ran the pertronix red wire to + coil and the black wire to the - coil.
So, both IGN 1 and IGN 2 run to the +coil. In this instance, is it ok to run the electric choke to the + coil?
