As Monte said,get the wheels and tires that you want and that fit your wheelwell,set them in the wells then measure the rearend length.Don't forget to allow for the thickness of the brake componants.You may also want to consider centering the wheel in the opening for front and back clearences and make the adjustment in your suspension attaching points.
