Well the issue settled itself. With initial clearance checks I started checking every valve and found one cylinder that had .009 clearance p/v. I've got another set of heads that haven't been milled as much.They will bring the compression down to 11.76-1 and are a set of 516's. didn't really want to use them as the flows will be off a bit.Dave
