Okay, thought I'd solicit some opinions and please explain why you'd choose as you do.
Combo is 360 +0.040", KB Hyper pistons very close to 9.5:1 C/R, repro 340 cam, valves have typical 3 angle job on I think 2.02/1.60 valves, tri-y headers. 4 speed trans, 3.23 sure grip and close to 4400 lbs curb weight. Trans is not the o/d unit. This is however, a truck that sees some towing duty. Currently running a performer intake with eddie 650 on it. It actually does not run poorly, it's just this particular intake has an issue with coolant leakage I've never managed to totally stop and I'm now thinking it's just plain porous.
So, if I get a new intake to use with the existing pieces, what should I get?? I'd kinda like to have a bit more grunt if possible but the cam is going to restrict that more than anything.
Let's hear your suggestions!
Mike
