there is an earth wire on the LH rear side marker to tail light to provide earth for the tail light body. the RH tail light earths from the trunk lock rod cover.
Thank you, I knew it looked factory but just wasn't sure which factory it was from. Barry or I neither one remembered seeing one before, but I'm not an E-body guy.
Careful, your character's showing!
