misses at idle/part throttle/wot? Describe the miss, what parts/systems have been replaced/checked. When did it start, any changes that immediately preceding it missing? Some times on a toughie I go back to a basic compression test to make sure I ain't got a dead hole. If you ground each plug wire does it slow a bit? rotor radial gap/phasing OK?
