My daughter's Durango takes at least 2 turns of the key before the starter turns. It has a 5.2l magnum, original starter, and a battery that's over 5 years old with 59,000 miles on it. The alternator is charging showing about 15 volts on the gauge. This morning the temperature was 4* and it took 5 turns of the key before the starter ran. After that, it started normally.
I'm suspecting the battery, but I'm wondering if it's something in the starting circuit.
Thanks,
Tony
Retired Mopar Enthusiast
